Re: Need advice on lempco 60 ton press.
Posted by Ozlander on May 11, 2017 at 19:33:30 [URL] [DELETE] :
In Reply to: Need advice on lempco 60 ton press. posted by Beth and Allen on May 11, 2017 at 19:10:45:
Well, you know the area of the ram is approx. 19.6 square inches.
And you know the desired force is 120,000 pounds.
And if you divide the desired force in pounds by the area in square inches, you get the required pressure in psi.
Hint, hint you need a 6,000 psi pump.
Use a good hose when you connect the hose.
