Re: Hydraulic Lift,,,again !
Posted by Charles(NC) on May 11, 2017 at 16:19:23 [URL] [DELETE] :
In Reply to: Re: Hydraulic Lift,,,again ! posted by JMOR on May 11, 2017 at 14:28:09:
The touch control is adjusted so as to touch (643) the housing as it reaches the top thus closing the intake spool valve(698).This is a early 8N.As said,,oil is moving,,none leaking at the lift cylinder,,but will hold lift arms up if I lift them (oil pressure? for a time.As has been stated ,,,,no pressure at the pump? Thanks
