Re: Hydraulic Lift,,,again !
Posted by JMOR on May 11, 2017 at 14:28:09 [URL] [DELETE] :
In Reply to: Hydraulic Lift,,,again ! posted by Charles(N.C.) on May 11, 2017 at 13:19:18:
Remove right side round inspection port and visually or by feel (below oil level), make sire control valve(s) spool(s) are actually moving when you move the touch control lever. The (s) is because I don't see where you said 8N or 9N/2N.
