Re: Hydraulic Lift,,,again !
Posted by R Geiger on May 11, 2017 at 13:33:55 [URL] [DELETE] :
In Reply to: Hydraulic Lift,,,again ! posted by Charles(N.C.) on May 11, 2017 at 13:19:18:
The only way to tell if the pump is putting out the required pressure is to put a pressure gauge in the test port.
I am not a fan of putting a new piston with o ring into an old cylinder, but if it works it works.
