Front mount coil
Posted by Bob E on May 10, 2017 at 23:50:45 [URL] [DELETE] :
I posted a couple weeks ago about my 1945 2N not running the best, well I did a compression test, new spark plugs, distributor cap, points, condenser, rotor, tested plug wires, cleaned carb and minor kit, cleaned sediment bowl, timed distributor. Problem was still lack of power on acceleration, some back firing, seemed to run better at full throttle then half. I had replaced coil a couple years ago with new one, but after fighting this lack of power for 3 weeks and missing engine, l had a coil from the used distributor assembly I bought at the salvage yard, the guy gave it to me, as a last resort I put it on and it ran the best It has in months. My question is am I alone with this issue on coils? It seems I need coils more often then spark plugs. Both tractors are front mount distributor, 6 volt originals. Thanks Bob E
