Re: Limited hydraulic movement
Posted by BlasterStumps on May 08, 2017 at 22:41:36 [URL] [DELETE] :
In Reply to: Limited hydraulic movement posted by Ted on May 08, 2017 at 21:39:22:
Control valve spool issue most likely. Either the spools are sticking in the bore or, the rod is not connected to the pivot.
