Re: New to me 8n
Posted by BlasterStumps on May 08, 2017 at 21:42:05 [URL] [DELETE] :
In Reply to: Re: New to me 8n posted by Doug on May 08, 2017 at 21:21:36:
If you are getting oil in the coolant, I'm fairly certain you will need to pull the head. Once you have the head off, you should see fairly easily where the gasket has failed. Hopefully it is only the gasket that has failed. I don't know about the air idea. may work?
If the engine is running and it is up to temp, you should see bubbles forming when you look in the radiator at the coolant if there is problem with the gasket.
