Re: New to me 8n
Posted by BlasterStumps on May 08, 2017 at 20:12:15 [URL] [DELETE] :
In Reply to: New to me 8n posted by Doug on May 08, 2017 at 19:06:38:
when you pull the head, inspect it real close for cracks between cylinders. Head gasket might be what's needed but head is suspect until you can rule it out. Sometimes the block can crack between cylinders but I would suspect other indicators then.
If all that is needed is the new gasket, remember to re-torque the head bolts after it has been run for a bit.
