Re: Three point lift / dirt scoop
Posted by BlasterStumps on May 07, 2017 at 08:27:14 [URL] [DELETE] :
In Reply to: Re: Three point lift / dirt scoop posted by Doug on May 06, 2017 at 22:37:20:
Pull the round cover off on the right side of hydraulic housing, using flashlight, look in and watch the cylinder to see if oil is flowing out. Do this with the tractor running and lifting. If no oil leaking, chances are then the cam follower pin is worn badly. Shut it down and then with light and mirror, take a look at the pin, if you can see noticeable wear, might need to pull top cover and rotate it or replace it.
