Re: Danuser post hole digger questions
Posted by Den N Ms on May 06, 2017 at 18:23:34 [URL] [DELETE] :
In Reply to: Re: Danuser post hole digger questions posted by Ultradog MN on May 06, 2017 at 17:28:58:
Usually a person wants a post hole to be drilled straight down and straight in line.A post hole digger is one implement that is a must use stabilizers With out the stabilizers a digger can and will flop as much as 12" side to side or lay to one side, and you can't dig a straight hole like that.It's hard enough digging good holes with a N and anything that helps improve the outcome is well needed so use the stabilizers.BTDT and tried it without them and it sucked.
