Re: Position control lever
Posted by Dan Chisler on May 06, 2017 at 11:41:37 [URL] [DELETE] :
In Reply to: Re: Position control lever posted by Ed Gooding (VA) on May 06, 2017 at 08:19:58:
Thanks Ed , I am getting it . The Draft control is just more or less up and down , But the Position lever keeps things at a desired level . I will have to play around with that . Last week did some spike tooth harrowing . some disk harrowing using an old horse drawn JD disk and some rollering ,and some two bottom plowing .I wonder what impliment would actually do what i want done ? leveling and cutting the highs and filling in the holes. also tried some grading .It would probably help if i did not have the sod.
