Re: Danuser post hole digger questions
Posted by Dan Chisler on May 06, 2017 at 11:11:19 [URL] [DELETE] :
In Reply to: Re: Danuser post hole digger questions posted by DED on May 06, 2017 at 05:35:38:
You are referring to the old telescoping danuser stabilizers from the fifty's That is correct . but what ford part stabilizer could be used on this 1970 Danuser mod I have ? is there any bars that were made that come from the fender bracket area?
Is the fender bracket the same alignment as where the lift arms mount ? it must be close if same then then they would work or maybe could be made .....Thanks for the response DED I also have a oil leak on one of the lift arm mounts that will be another subject . I hear i have to remove the whole axel to get at the nuts . Both turn .Thinking of doing a clean up and try some gray rtv ....
