Re: Position control lever
Posted by Ed Gooding (VA) on May 06, 2017 at 08:19:58 [URL] [DELETE] :
In Reply to: Position control lever posted by Dan Chisler on May 06, 2017 at 00:53:50:
You use draft control for tillage implements (plows, harrows, cultivators) for the reason Charles stated below.
You use position control for about every other implement so you can set and hold the implement anywhere along the high-low range that you want.
Hope this helps..............Ed
