Danuser post hole digger questions
Posted by Dan Chisler on May 06, 2017 at 01:01:08 [URL] [DELETE] :
I have a 1970,s danuser post hole digger . There manual says be sure to use sway stabilizers . On the old 1950 Danuser diggers they had long telescoping stabilizers
The newer diggers do not have all that .To use regular ford stabilizers the lift would not be able to go up and down unless the bolts were left loose . but then what use would that do . I am only using a 4inch auger so I am thinking if i be care full maybe i can get by with out the stabilizers . Any thoughts on the subject from those who are in the know ?I will be using a 8n or 9n tractor with the digger .
