Re: 1952 Ford 8N
Posted by DED on May 05, 2017 at 05:45:01 [URL] [DELETE] :
In Reply to: Re: 1952 Ford 8N posted by 36 coupe on May 04, 2017 at 19:28:12:
Thanks to everyone. It has been changed to 12 volt and has worked 100% since the change which was about five years ago. When the started button is pushed it does not turn over as quickly and start as easily. There is a grinding noise. It will still start. I have never had to crank it for any length of time as it always started on the first turn. I did have sparks coming off of the solenoid when starter was engaged but that has quit since I cleaned and tightened all of the terminals. Tractor is covered when outside and from Oct. to April is garaged.
