Re: 1952 Ford 8N
Posted by Gaspump on May 04, 2017 at 19:33:52 [URL] [DELETE] :
In Reply to: 1952 Ford 8N posted by Dead Eye Dave on May 04, 2017 at 13:43:41:
If you suspect the starter is not grounded properly you could use a jumper cable connected to a clean spot on the engine to the same on the starter. If it then spins lively it could be poorly grounded. Starters don't often have a poor ground unless everything is heavily painted or corroded including the bolts.
