Re: 1952 Ford 8N
Posted by K.LaRue-VA on May 04, 2017 at 16:43:58 [URL] [DELETE] :
In Reply to: 1952 Ford 8N posted by Dead Eye Dave on May 04, 2017 at 13:43:41:
Yes, the starter bolts can be partially backed-off enough to slip a file in the gap to clean the surfaces. When done and starter is tight again. If you need a little more room to work, just use the tip Tim mentioned (a couple of nuts) to hold the starter together.
