Re: 8N steel tip-toe wheels
Posted by Charles Krammin on May 02, 2017 at 19:26:21 [URL] [DELETE] :
In Reply to: Re: 8N steel tip-toe wheels posted by Tim Daley(MI on May 01, 2017 at 13:09:00:
Used a Ford 600 one year to help pull the corn picker through wet spots. They were 4" less diameter than the tire size. The F-20 pulling the picker, had to bump the Ford through the wet holes as it was spinning so it could final pull the F-20 through. They were used in the muck area here. Didn't think they helped in this situation. They were only about 2" spikes.
