Re: Dirt Scoop
Posted by Tim Daley(MI on May 02, 2017 at 11:54:35 [URL] [DELETE] :
In Reply to: Re: Dirt Scoop posted by Jim A Ok. on May 01, 2017 at 11:03:32:
I've found WD-40 to be nothing more than low-grade vegetable oil -good for squeaky hinges and not much else. I suspect they changed the formula about 20 years ago as it use to be the go-to lube all for most home projects including gun oil. Many products now are EPA controlled and watered down versions of what they once were...literally.
