Re: How easy should I be able to turn over the engine by hand?
Posted by Den N Ms on May 01, 2017 at 23:40:21 [URL] [DELETE] :
In Reply to: Re: How easy should I be able to turn over the engine by hand? posted by 36 coupe on May 01, 2017 at 08:47:35:
Marty,You said,Bad news, did the one wheel thing, and no movement. Now what?Well,did it loose oil pressure the last time you ran it.If you can't turn it with a pry bar,plugs out,starter out you have problems.Time to pull the engine and tear it down.The rods and mains,or the pistons are seized up.The engine has to have oil pressure to stay running.
