Re: How easy should I be able to turn over the engine by hand?
Posted by steveVa on May 01, 2017 at 23:33:58 [URL] [DELETE] :
In Reply to: Re: How easy should I be able to turn over the engine by hand? posted by Marty on May 01, 2017 at 22:48:42:
Marty, one thing, you should put it in high gear when you turn the tire or try to pull it. It may be opposite then you would think but in high gear you have more leverage to turn the engine with the tire. What kind of oil pressure did you have prior to this happening? You are right that it is odd that you would shut it off and then it would seize up. Something could be jammed. Did it have OK oil pressure?? Like 20psi when hot??
