Re: How easy should I be able to turn over the engine by hand?
Posted by 36 coupe on May 01, 2017 at 08:47:35 [URL] [DELETE] :
In Reply to: How easy should I be able to turn over the engine by hand? posted by Marty in MI on April 30, 2017 at 18:36:14:
You need a hand crank.Engine is stuck from sitting idle.Using the rear wheel dosent give the feel you need.The clutch can slip and fool you into thinking the engine is free.
