Re: How easy should I be able to turn over the engine by hand?
Posted by steveVa on April 30, 2017 at 22:08:45 [URL] [DELETE] :
In Reply to: Re: How easy should I be able to turn over the engine by hand? posted by Marty on April 30, 2017 at 20:57:04:
I also meant to say that the starter bendix could be jammed to the ring gear. Sometimes rocking the rear tire back and forth while in high gear will kick it loose, so be careful. Good luck with it.
