Re: How easy should I be able to turn over the engine by hand?
Posted by Den N Ms on April 30, 2017 at 19:02:59 [URL] [DELETE] :
In Reply to: Re: How easy should I be able to turn over the engine by hand? posted by Marty In MI on April 30, 2017 at 18:47:25:
Marty,If you can't turn the flywheel through the hole with a pry on the flywheel teeth,something is wrong.Is the starter still on it?If it is still on it the drive could have it bound up.Loosen the starter up or remove it and try turning it with a pry through the starter hole.
