Gasket, sediment bowl
Posted by murray2 on April 28, 2017 at 20:40:10 [URL] [DELETE] :
Hi, having a problem getting a sediment bowl gasket to make a proper seal. The one
purchased from a Ford dealer had a rubber gasket which did not stop the leak, have
tried several cork gasket's none will stop the leak. The replacement sediment bowl
assembly must be out of shape and prevents the proper seal. Thanks for any advice.
Cheers Murray
