Re: Cleaned pump, doesn't work
Posted by BlasterStumps on April 26, 2017 at 23:17:06 [URL] [DELETE] :
In Reply to: Cleaned pump, doesn't work posted by Tom on April 26, 2017 at 23:07:09:
-be sure your PTO is engaged and PTO shaft turns
-check to see that the control rod is connect to control valve pivot at pump and that the control valve spools are moving in and out when you move the control lever
