Re: Hydraulic fluid mistake
Posted by KEvin on April 25, 2017 at 12:45:00 [URL] [DELETE] :
In Reply to: Hydraulic fluid mistake posted by Kevin on April 22, 2017 at 19:56:42:
I removed the bleeder plug on the pump and used compressed air in dip-stick hole to flush some UTF through the suction line to the pump. Looked like the right stuff coming out of the bleeder, clearish with a slight blue color. Seemed a little thicker than when I poured it in but not dramatically.
So I set throttle to abou 1000 RPM and backed off the plug a bit. After a few turns, I got a steady seep of fluid from the bleeder.
