Do I need a Major
Posted by Bob E on April 23, 2017 at 11:09:07 [URL] [DELETE] :
I own a 1945 Ford 2N with a front mount distributer,I do a lot of things from plowing to corn picking. Problem is that I can't seem to get it to run nice anymore. I did a cold dry compression test with the front cylinder being 75, second 60, third 50 and the fourth 70. The oil pressure cold is not over 25kbs and warmed up around 10-12lbs. The tractor does not smoke or use oil to speak of. The tractor runs nice at times but throttling up you can feel and hear the lack of performence. I have replaced the points, condenser and spark plugs. The wires are good, {just a few years old}. All I know is I have to do something or the fun is going to stop.Any ideas out there? Thanks Bob E
