Break drum help
Posted by Doug on March 19, 2017 at 12:29:26 [URL] [DELETE] :
Got the wheels and tire all mounted up and took the tug for a ride around the block. Ran great rattled here and there but I was expecting that. However, when you stepped on the break to stop the right wheel would clunk and lock up. Back in the garage on jack stands. Pull the wheel and attempt to pull the break drum. We have tried heat and kroil around the hub and studs. No luck, can anyone offer a little help on a trick to removing the drum.
