Re: Spark
Posted by Bruce (VA) on March 16, 2017 at 16:51:43 [URL] [DELETE] :
In Reply to: Spark posted by Roger on March 16, 2017 at 09:31:11:
First, get rid of the spark test light. Get an adjustable gap spark checker & open it to 1/4". :
https://www.amazon.com/Adjustable-Energy-Ignition-Spark-Tester/dp/B01DP6STUI/ref=sr_1_fkmr1_1?ie=UTF8&qid=1489696976&sr=8-1-fkmr1&keywords=adjustable+gap+spark+checker
Meanwhile, you have a weak spark. The most common cause of a weak spark is a weak battery. Charge it (see tip # 60) and check it .(tip # 49)
Be careful jumping it; see tip # 43).
Other causes of a weak spark, in no particular order and probably not all inclusive, bad grounds/connections, worn plug wires or carbon core (automotive) plug wires, wrong plug gap, wrong plugs or burned plugs, worn out rotor/cap/points, incorrect point gap, worn insulator on the side of the distributor, incorrect or burned out resistor & a worn out ignition switch putting resistance in the circuit. Rarely, a bad coil..
