Re: Hydrolic Pump Help
Posted by Charles (N.C.) on March 16, 2017 at 12:22:36 [URL] [DELETE] :
In Reply to: Re: Hydrolic Pump Help posted by Tim Daley(MI) on March 16, 2017 at 11:55:47:
Tim,,,yes I did use NAA B530 piston with the new neoprene O ring but this came with a plastic backup washer.Leather is best but it's what was in the pkg.There is no fluid leakage from the top so no doubt the problem is the lower pump.I see no turbulence from fluid in the rear housing.As I recall both these tractors hydraulics worked but they have sit for a long time.Thanks
