Re: Spark
Posted by Roger on March 16, 2017 at 12:16:33 [URL] [DELETE] :
In Reply to: Re: Spark posted by Tim Daley(MI) on March 16, 2017 at 11:46:04:
Thanks, Tim. I replaced the condensor but not the rotor. My old one looked to be in good shape and fit better than the new china one. Pigtail to coil is good (all wires are only about a year old), gapped points and plugs, but didn't mess with the timing since it ran fine before. Engine has about 95 lbs on all cylinders, which I know isn't great, but it should still run? By jummper assist I mean using a 6V charger/jumper box which spins it slightly faster. Just seems odd that the first crank gives a hot spark, then little to nothing. Carb is good as it was recently rebuilt and ran fine on another tractor.
