Re: Spark
Posted by Tim Daley(MI) on March 16, 2017 at 11:46:04 [URL] [DELETE] :
In Reply to: Spark posted by Roger on March 16, 2017 at 09:31:11:
HiYa Roger-
Will engine turn over at all? Did you check everything else when you did a point replacement on your front mount? New rotor and condensor too? Check the pigtail on coil to ensure it is making contact? Points gapped at .015" Timing set correctly? On Bruce(VA)'s 75 Tip list, check #13 and #43. By 'even with jumper assist on battery' do you mean jumping from your car or truck 12 volt battery? Are plugs fouled? If so, dry off with an electric matchstick or torch, run a brass wire brush over tip, gap at.025 - .027 and reuse.
