Cleaning Shaft
Posted by Charles (N.C.) on March 12, 2017 at 16:00:34 [URL] [DELETE] :
In Reply to: Re: trying to replace a lift arm on a 2n tractor posted by travis on March 11, 2017 at 11:53:51:
Travis,,most any lub like dezil fuel etc. will do to clean the splines.I use a small cleaning brush and sometimes a tooth brush to scrub with,,just get the hard junk off and then a light grease to lub the splines.You do have to clean "both" shaft and arm for this to work.If all is well a rubber mallet is all thats needed to tap them togather.Block the other side shaft helps.
