Re: trying to replace a lift arm on a 2n tractor
Posted by Charles (N.C.) on March 08, 2017 at 09:05:55 [URL] [DELETE] :
In Reply to: trying to replace a lift arm on a 2n tractor posted by travis pruitt on March 07, 2017 at 21:35:38:
If your trying to replace the lift arm on top of the rear end there is only (1) way they will line up.The splines are made this way.Now if you bent/buggered up the splines removing the lift arm then you will have a problem.Clean the splines real well on the lift shaft for a "lookie".
