Re: Remmoving 8n dist
Posted by Jack - Iowa on February 28, 2017 at 16:55:42 [URL] [DELETE] :
In Reply to: Remmoving 8n dist posted by jhill52 on February 28, 2017 at 12:23:39:
You will likely find it easier to get the distributor out if you take the belt off and get the generator out of your way. On my 2N, which does not have the original generator on it, that means removing the generator.
I personally remove the distributor and coil as one package. Either way.
Also would suggest you mark plug wire 3 and 4 as it is very easy to cross those when you re-assemble it.
I am not able to answer your question regarding removal of the loader.
Good Luck,
Jack
