Re: Jubilee live pto
Posted by TheOldHokie on February 27, 2017 at 11:44:31 [URL] [DELETE] :
In Reply to: Re: Jubilee live pto posted by Walt/Tx on February 27, 2017 at 11:19:44:
The NAA Live PTO option is a hydraulically actuated (by hand lever) clutch pack installed in the coupling between the transmssion and differential. Disenginging the hydraulic clutch with the hand lever will disengage the transmission from the drive wheels causing the tractor to drift to a stop but leave the transmission connected to the PTO and the PTO running. Depressing the foot clutch will cut power to the transmssion input shaft. That disconnects the engine from both the hydraulic clutch and the PTO stopping the drive wheels and the PTO as it always did.
TOH
