Re: Carb question
Posted by K.LaRue-VA on February 24, 2017 at 19:32:02 [URL] [DELETE] :
In Reply to: Carb question posted by Tom on February 23, 2017 at 15:51:39:
I rebuilt one carb with a backward choke shaft. I bought it without carefully studying the photos. No big deal to put the standard N-tractor choke shaft in it. Just drill the hole the rest of the way thru the body and then counter-bore correct size for the seal. I made a brass plug to close-up the hole thru the "wrong" side. Installing another seal on that side might have worked just as well.
KL
