Re: Carb question
Posted by Rustyal on February 23, 2017 at 17:27:26 [URL] [DELETE] :
In Reply to: Carb question posted by Tom on February 23, 2017 at 15:51:39:
If it is really a 241 you should be able to move it to the correct side. Since it would have been on the throttle shaft side to start with. Someone could have mated a 241 top with the wrong bottom. Although the bottom half is normally labeled in the spot your choke shaft is now located. So?? Hmm.
