Re: Carb question
Posted by Tim Daley(MI on February 23, 2017 at 16:52:34 [URL] [DELETE] :
In Reply to: Carb question posted by Tom on February 23, 2017 at 15:51:39:
HiYa Tom-
First let's be certain we are all on the same page. The TSX 33; TSX-241-A; and TSX-241-B carbs used on the N's should all have the throttle shaft lever linkage and the choke shaft lever linkage on the same side of the carb -the side that faces inward toward the engine. How one got reversed is beyond me. The choke lever is a blind hole as the side facing out has the cast paddle boss where they fasten the brass model and ID tag to on the 241's. Can you post pictures?
