Question for the 12 volt expert
Posted by poderac on February 20, 2017 at 21:47:07 [URL] [DELETE] :
Using two 12 volt batteries connected in series, running a 24 volt motor.
I only have a 12 volt charger. If I hook the charger up to one battery, then jump it to the other battery, in parallel, will it charge both at the same time, or will I have to remove the series jumper before it will work?
