Re: battery education in need
Posted by Bruce (VA) on February 20, 2017 at 21:33:15 [URL] [DELETE] :
In Reply to: Re: battery education in need posted by Don B. on February 20, 2017 at 21:25:47:
The cut out is not preventing the tractor from starting.
You need a strong battery to:
1. Spin the starter
2. Engage the bendix
3. Provide voltage to the coil.
As the battery gets weaker, the first thing to fail is your spark.
The more current you use to spin the starter, the less you have for the ignition.
If your starter pulls that battery down much below 5.2 volts, the module in the EI will not fire.
It doesn't really matter much if the battery is "fully charged" until you test it correctly. What did the load and hydrometer tests show on your battery?
