Re: What to do with 8N?
Posted by steveVa on February 19, 2017 at 17:12:57 [URL] [DELETE] :
In Reply to: Re: What to do with 8N? posted by Del Huebner on February 19, 2017 at 11:05:59:
All the more reason to add some MMO and run it a bit. Nothing to loose. Those rings might free up some more. Worse case I see for now is if it doesent clear up you pull the head and chech head gasket between 3 and 4. Many a tractor smoke on accelleration. I WOULD RUN IT TILL IT FOWLES A PLUG. If it ever does...
