Re: Front loader removal
Posted by Frank (WNY) on February 18, 2017 at 18:22:50 [URL] [DELETE] :
In Reply to: Re: Front loader removal posted by John in Mich on February 18, 2017 at 17:46:56:
Thank you John. I was wondering about the pump. It is the front crankshaft driven type. I wasn't sure if I should loosen the mount bracket bolts to relieve the pressure when the rear end of the FEL is raised. I'm not sure how much play there is between the stinger shaft and the drive plate.
