Re: Front loader removal
Posted by John in Mich on February 18, 2017 at 17:46:56 [URL] [DELETE] :
In Reply to: Front loader removal posted by Frank (WNY) on February 18, 2017 at 11:47:27:
You did not mention the hydraulics. If it is a front pump driven from the crankshaft you will need to unbolt the coupling between the pump and the stinger shaft. I roll the tractor back by hand and remove the stinger shaft from the engine pulley before starting the tractor.
If you are using the belly pump you need to shut off the supply and disconnect the hose.
Also, if you have a grill on your tractor, lower the front of the loader until you are sure the mount bracket will clear, then block the loader.
