Re: Fuel line on a 621
Posted by Jack - Iowa on February 15, 2017 at 22:10:30 [URL] [DELETE] :
In Reply to: Re: Fuel line on a 621 posted by Doug on February 15, 2017 at 12:11:15:
Doug,
One word of caution. The bolt which holds the sediment bulb in place is a hollow bolt and has a hole through the side which must line up with the passage inside the sediment bulb. The sediment bulbs are manufactured with the that passage either to the left or right of center. You must match the bolt to the bulb assembly. You can spot the difference by the fact the fuel line comes down either to the left or right of center also. Hope this is clear! My 860 was one way, my brother's 861 the opposite.
Good Luck,
Jack
