Re: 9n blown head gasket or cracked head
Posted by steveVa on February 09, 2017 at 11:16:00 [URL] [DELETE] :
In Reply to: 9n blown head gasket or cracked head posted by Jerry Gere on February 08, 2017 at 23:10:09:
Sounds like it could well be a blown head gasket. Also sounds like your distributor got wet and you need to dry out good and set the points and clean all the connections. Sometimes just unpluging the plug wires and putting them back restores a good connection. If you were nose down and the radiator was overfilled it may have just overflowed and not overheated.
