Re: Camshaft Gear
Posted by Bruce (VA) on February 08, 2017 at 16:00:57 [URL] [DELETE] :
In Reply to: Camshaft Gear posted by SteveH on February 08, 2017 at 14:29:51:
" plan on rehabbing the governor as well as I suspect it may have contributed to the failing of the gear with improper RPM's?"
Probably not.
Just make 100% sure you line up the index marks on the camshaft gear w/ the crank.
