Re: 9n wiring
Posted by Den N Ms on February 07, 2017 at 22:17:11 [URL] [DELETE] :
In Reply to: 9n wiring posted by Rick on February 06, 2017 at 10:29:24:
Rick,It sounds like your charging system is not working and you have a discharged battery.Check the battery voltage before jumping it ,then again when you have it running with the jumper cables unhooked. Low voltage will cause it to miss,sputter and backfire.
