Re: charging troubles
Posted by JohnB on February 07, 2017 at 08:32:19 [URL] [DELETE] :
In Reply to: Re: charging troubles posted by Tim Daley(MI) on February 07, 2017 at 08:00:30:
Tim, I don't have the regulator in front of me, but I recall seeing the factory p/n and the words "6 volt positive A circuit" silkscreened on the top of it. I will look closer when I get home.
The "original" regulator had some damage to the field contacts. There was enough build-up on the contact face that the two contacts stuck together. I have repaired it as best I can and plan to try it again this afternoon.
The wiring on this tractor has been a mess since I bought it (hence, the need for a rewire). Only recently have I attempted to get it sorted out.
